What to buy ?
I need to decide what to buy ?
Arlo Pro + base OR Ring Stick Up Cam ?
Arlo have a base , Ring doesn't
Both wire free , Ring with solar panel
Both almost the same price
What i am missing ?
Any advice will be appreciated .
First do you need it Indoors or Out?
Second , do you have good exterior lighting and a window where you want it?
Third, do you need audio?
In all, I would go for the PRO as you can later expand the system to a max of 5 cameras FOR FREE ( not with ring ) and, Have local recording ( and same time cloud ) with the PRO, the Pro will give audio 2 ways.
The solar panel for the Pro will be coming.
If you can live without audio and there's a window, the indoor ac powered Q cameras will work thru glass well as detection is pixel based ( just can't use night vision thru glass )
In the end..ask good questions and make an informed choice ! 🙂
(of course asking here we tend to have a bit of bias)
Thanks for your reply .
I need outdoor without sound or audio .
I have good lightning .
Don't need local recording .
The solar panel for the Pro will beat additional cost , at present the price is almost the same with ring solar ...
Don't understand : " expand the system to a max of 5 cameras FOR FREE "
Free ? Each addition camera cost $189.99 or I don't understand .
I would lean to the PRO in case you change your mind later re audio...
As to the "free", not that the cameras are free, BUT the 7 days of storage is free for up to 5 cameras if you want to add more cameras later. This 7 days of record is NOT a trial period but for ever... ( on day #8, day #1 is deleted automatically and you can d/l if you want to save )
Ring charges; After the thirty day trial period, optional Cloud Video Recording subscriptions are $3/month or $30/annually for each Ring Doorbell.
