Viewing Saved Favorited videos past 7 days
  • 7747 Views
greenbrg
Hello so I have 6 cameras on the basic plan with a 2TB drive on the hub and cannot view the Favorited videos that are past 7 days old. I would think that you would be able to view past Favorited videos from your hub etc... Do I need to unplug my drive and view them on a computer? Is it organized by date and camera name?
Favorites are just a way of filtering the videos... they are deleted after 7days if you have a basic plan.
The best thing to do is d/l any files you think you may want to keep.
As you know they are also on the usb backup if enabled.  Locate either by file create date AND/OR the long numeric name which is in Epoch time
To convert to human date/time , go here  https://www.epochconverter.com/
greenbrg
So just to be clear, if you faviorte a video it will not be saved on the local USB hardrive?
pc2k17
Hero
Hero
All videos get saved to your USB drive plugged into the base. Even favorited videos, although that designation is only used in the app, they won't be marked favorite on your USB drive. To view the videos on your drive, first safely eject the usb device using the app. Then unplug your drive and plug it into a computer. The files will be named in the format explained in the above post.
