yes and no.....
biggest issue is lack of flash for Live playback on the TV
I can stream save/recorded videos to my Samsung but they are in mp4 format which the tv support.
If you can stream with a sling box or similar to your tv direct from a computer , then yes ...but not directly most of the time
yes and no.....
FWIW, I can use the Chrome browser on my Samsung Smart TV to view the site. As mentioned, the lack of Flash makes live view unusable but you can do 99% of everything else with no problem, including checking the library.
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,335
						Videos1
