VMC3030 motion detection is not working. Showing "the device does not exist"
Motion detection not working. No red lights come on with any motion. There was a problem with 'the device does not exist' , however, that has fixed itself with numerous re-syncing. Any suggestions on the motion detection?
I also re-synced to the base numerous times. Still no motion detection.
Update: I just rebooted the base, leaving it off for 20 minutes. Still no motion, but there are no lights on for live feed viewing. Any suggestions on how to fix the red lights to come on? Thank you.
These will only operate when the light level is low such as nighttime.
Have you tried checking the motion detection utility from the camera settings.
Look for it on the video settings page in the camera settings.
Toggle to confirm correct operation, remember that the LEDs only turn on when motion is detected by battery cameras. The motion detector does not utilise the LEDs as they are only used to illuminate objects for the camera to see in the dark.
It is very easy to accidentally select -2 without knowing.
Pull out batteries and re-install to reset camera.... I would also do a power button reboot of base ( give 2 mins to reboot )
Verify the Night vision is turned on in the mode settings...
Test in a dark room, the IR leds are 850nm so they should just be slightly glowing red when on.
The brightness is set at 2 (and it is dark in the video settings as well, I slid it to -2 and back but no change) and the night vision toggle switch is on (I also turned it off and on again with no difference) I have had no problems before, until now.
I keep moving the batteries around and I rebooted the base station several times. The last time I left it off for 20 minutes. Also, the night vision switch is on (I also slid the toggle on and off) but no difference.
There are no red illuminating lights with the motion or viewing live feed.
I had the lights come one time, then no more. I did a resync and moved batteries around. Now I am getting a message on the device tab; This device does not exist.
I think my camera is 'done for'. I wish we still had support.
Either way arlo support is the next best option for cameras still in warranty or you have a subscription.
