VMB4000r3 Base Station and Cameras Showing Offline Using Edge or Chrome Browsers
When I view my cameras thru my Android, they are all working just fine.
When I look at the cameras thru my PC at my.arlo, they all show as offline, as does my Base Station.
I have rebooted my router and the Arlo Base Station. No difference.
I have turned off my firewall: No difference.
I am not using a VPN.
If I arm the system using the Arlo App, the cameras record video and I can see the recordings on my PC.
Help would be greatly appreciated.
Thanks for letting me know, I will look in to these reports and provide an updates as soon as possible.
I was not potshooting at you, I was aiming at arlo when it seems that some customers have a flawless experience, maybe subscription is needed going forward.
I am happy to continue with posting when I can help, I was referring to this web portal issue when it gets raised.
I've been watching this for about two weeks and figured I would post it.
There is a difference between Web and Mobile ARLO Secure stats. Not with all cameras, but it seems to be with the
cameras that are now using the XL battery. I replaced on battery two days ago when the indicator showed 14%. I replaced it and from the Web it still shows 14%.
Now when I look at it from my Mobile interface, the same camera shows 90%
From my Web sessions, I've cleared all cookies, cache and the normal things you would do when web pages hang around. I tried different browser and even different computers. All show the same 14% for that one camera.
I generally run with a VPN connected (Avast), but I can toggle that back and forth and it doesnt change anything.
I tested this out with another ARLO account I use at home. Looks like the same thing ... Different battery percentages stated for the camera with the XL battery.
Now when I am just Web running, that 14% camera goes offline and I have to turn it on again. Is the ARLO Secure from the Web listening to the 14% and turning off the camera? While the Mobile always has the camera on.
For now, I am going to hold off using the Web interface.
Both Web and Mobile ARLO Secure is at the latest level.
Hi All,
I was informed there was an update to the web client that should resolve this issue with your device appearing offline and having inaccurate battery percentages.
Please let me know if you are still experiencing an issue with your devices.
Not sure what web version is out, mine says 3.6.12_1
no improvements with camera battery status or percentage. Camera on/off condition still not updating.
@Dannybear
Thanks, I just notified the dev team. I'll probably have an update Monday for you.
cheers,
i am in AU so that may explain a lot.
Still showing offline for me.
Got a strange issue going on with our cameras, particularly 1 of them, we can view it fine via mobile devices but as soon as it comes to viewing it from a desktop device, it says its offline with 0 charge. I thought maybe it was a issue with the browser but changing how we view it does nothing. Our 2nd camera works fine too. Out of trial and error i swapped the batteries around in the cameras to try and determine the cause. Unfortunately doing this did not remedy the situation. Contact have been cleaned inside the camera too. Could the camera itself be at fault?
I have a subscription with 10 cameras, two of which connect to WI-Fi while the other eight are conected to an Arlo base station.
Recently, the eight cameras show "Offline" when viewed on a laptop but can be viewed live on the iPhone app. The two that are connected to WI-FI can be viewed live on both l A strange anomaly!
No - if it were at fault, the app would show the same status.
It's a problem either in the Arlo Cloud or their web client - several folks here are reporting the same issues. One of my own cameras is doing this.
Thanks for the reports, I have notified the team last Friday. I should have an update soon.
Quick question, Have you tried clearing the webs cache and test again?
Update on my end: After logging in my account, all my cameras except for one Arlo Pro 2 now works fine but after a few minutes, all go down Offline again. I already cleared cache today and same results.
@_JR_
Noted.
Thank you
same with us, clearing the cache on all desktops using the web client does not seem to make a difference.
When using the Arlo portal through Chrome, two of my cameras say "Your Arlo device appears offline" when it's not. When using the Arlo app on my phone, all works well. I've tried to power off, resynch and it hasn't helped. I've also accessed the portal thru MS Edge and have the same problem. Anyone have any advice? Thank You
Why, if I switch between the app, and the website, is the status of my cameras completely different? Not just a little different, significantly.
For example, I recharged the battery of one of my cameras last night. It is accurately reflected in the app, however the website still says it is not charged. The lag in updates appears to be abysmally slow, several hours at least.
I would expect a security platform would put more effort into ensuring their infrastructure was robust and fault tolerant. As an Engineer I find this wholly unacceptable.
All cameras show offline on PC, Android and IPhone. Turn all cameras on then logout, log back in and they show offline again. Also show inaccurate battery reading.
Like a number of other users, as I see from other Community threads, I am seeing problems with the browser app showing "device appears offline" even though the devices are actually working fine and sending current recordings to the cloud. I see this problem under both Chrome and Edge. A message from JamesC on 09/14 in another thread indicated that the cloud team released a fix for the problem. However, I am still having the problem today.
Fwiw, my devices are VMC3030, with good batteries, and my base station is VMB3000, and one of my "offline" cameras is now 3 feet from the base station.
Has anyone found an issue where the camera connects and is viable on the mobile app but it appears offline on the Arlo desktop software? I cannot find a solution. Thanks!
No, no solution yet.
This same thing is happening to me. I have tried restarting my base stations, I have three VMB3000. There is one camera, all Arlo Wire-free, on each of the base stations that started doing the "This device is currently disabled and will not respond to mode change" thing about two days ago. I have tried removing the cameras and readding them. I tried renaming them and adding them back to the base stations. No luck. Getting pretty frustrating. Does anyone have any ideas? Thank you.
I’m having the same problem. 2 of 3 disabled themselves and when I try to turn on in the app the button turns green to show they are on but they never come on. We’re working fine a week ago.
This issue has apparently not been resolved. All troubleshooting has been tried and proven ineffective. Cameras appear offline on the desktop arlo dashboard when they are actually fully charged and functioning on the Android mobile arlo app. Waiting for the fix.
