  • 17 Replies
  • 8159 Views
  • 13 Likes
  • 7 In Conversation
Andeyy
the cameras worked, but stopped working on 04/08/2022. The base is not connected to the Internet
Arlo has never sold any products or services directly inside Russia, but a small number of Arlo systems were nevertheless being used in Russia.  In light of the war in Ukraine, Arlo has shut off all services to those devices and will not allow the connection of new devices in Russia.
17 REPLIES 17
A lot more details are needed. What have you tried, what do you see? What has changed? What are the LEDs on the base showing?
Andeyy
after it stopped working:
rebooted the base, rebooted the router, connected the base to another provider
LEDs light up green-orange-green
The application says the base is not connected to the Internet
Yup, there appears to be a connection problem between the router and Arlo. What happens if you use ping to arlo.com (use a command prompt "ping arlo.com" or a phone app)?
Andeyy
I have a second base in a country house and the same problem with it
Interesting - is a VPN in use?
Andeyy
VPN is not used
In what country are you located?
Andeyy
Russia
@Andeyy wrote:
Russia
That is likely why.  But it's not clear who is disrupting the service.
Andeyy
How to solve this problem?
Not sure you can.  Maybe a router-hosted VPN?
Andeyy
is it possible to connect cameras directly to the base without a cloud service?
The cameras are connected directly to the base.  But you can't connect to the base without the cloud service.
I'm tagging @JamesC, in case he can clarify if Arlo services are disrupted (or suspended) in Russia or not.
VladimirK
Андрей, добрый день.
Удалось ли как-то в итоге обойти блокировку в РФ?
Z-Russian
Arlo, For some reason, ordinary, ordinary users suffer because of your actions, do you want to play politics?
Vladimir78
Arlo, for what reason did you decide to block users of your products from Russia? Or do you have a democracy, as ordered, and do you? Did you spit on your product and your reputation?
