VMB4000 base station chirp every 15mins
  • 1 Reply
  • 1445 Views
Cchen
VMB4000 base station chirp every 15mins, tried cycle the unit, still chirping.
If chirping and it was not solved by a power button reboot, then an option is to do a RESET* on the base...
Problem is that requires a full setup as if new.
You choice if nothing else fixes the issue
*( hold reset for ten sec till leds flash amber )
