VMB4000 What are the supported and available camera options?
  • 1 Reply
  • 804 Views
M_yaserkhan
Hello,
I’m using Arlo Pro (wireless) setup of VMB4000 with 2 camera xH8. I need to buy additional cameras. What are the supported and available options? Thx
brh
@M_yaserkhan
You can use either the Wire Free HD cameras, (the original cameras), the Pro or Pro 2 cameras. All of these cameras will work withyour current base station. Just do some research on the cameras to see which ones have the features. The main difference between the Pro and the Pro 2 cameras is that the Pro is 720P and the Pro 2 is 1080P which gives more detail in your videos.
Brian
