Is the Arlo Pro camera compatible with my VMB3000 base station? If not which amera should I get to add audio to my existing setup?
Thanks.
Yes... I'm running a PRO model on the Arlo 3000 base right now.... no problems ( maybe one minor )
You will get the audio with the regular base but the local record and siren are built in the PRO base so that you won't have that.
As to the minor problem, audio was fine with a PC, med level with IOS and was a bit low on some Androids... there was a sw update to fix that but no sure if fixed on all android combos
