Why is this update failing?
Worryingly, all my cameras are now not working - Update failure 1.16.2.4_3503
Same for me, keep getting "Base Station Error 4403" when it tries to update the firmware on VMB4000r3
Rebooted the base station and the update error has gone. Not sure if its updated or not, the version is showing 1.16.2.4_3505_f475f1
Hi
I received a message that I need to update my base station but keep getting the message Receiving error "Base Station Error 4403"
The base station is in a different country so I cannot do a switch off and on.
any solution
You should be able to restart the base station from the mobile app or the arlo web portal.
I used the mobile app to restart mine and it worked fine.
Go to Device Settings of the base station and there should be a Restart option.
Hello,
Simple solution just do restart remotely and once the system will go back online the software / firmware will be updated.
Good luck
