Unable to turn audio off
  • 2 Replies
  • 146 Views
A_Mc
Ever since the upgrade I have been unable to turn off audio detection. I have turned off the microphone, the speaker, moved the volume level all the way until it's grayed out and still I am getting every slightest sound setting off a notification and filling up my event library. Right now there is wind and I don't want to pick it up and I don't want to turn off motion and shut the whole camera down. This is very annoying as I was able to control this just fine before the update.
A_Mc
That was helpful but what really fixed the issue was going to...
1. Devices
2. Click the Gear on the camera I need to adjust
3. Select "Default Mode Settings"
Now I can set that camera's sensitivities (both motion and audio) to what I want.
Is audio detection turned off in the rules in the mode(s) you are using?
Also, go into the smart detection settings and make sure CO/Smoke detection is disabled.
A_Mc
1. Devices
