I purchased an Arlo Pro system with a basestation and 3 cameras from amazon. After following the directions exactly, I was unable to pair any of the 3 cameras with the basestation. I spent an hour with Arlo tech support repeating this process. They sent a replacement basestation. I repeated with the new basestation and it also didn't work. I returned the original system to amazon. They sent a replacement and I have the same problem. Here is everything I've tried:
- Battery powering the camera
- Wall powering the camera
- Battery and Wall powering the camera
- Angling the camera towards & away the basestation
- Putting the camera inches, 1 foot, 2 feet, 3 feet & 5 feet from the basestation while syncing
- Pushing the basestation sync button 1st & 2nd.
- Syncing the camera with the router and modem off
- Plugging the basestation directly into the modem
- Powering the camera from the basestation
Not sure what could be to blame except the firmware. The cameras can't all be broken. The basestations can't all be broken.
Customer service said they won't help me unless I try it at someone else's house. Any other ideas?
Additional:
When attempting to pair, the camera light slowly blinks blue for around a minute, the fast orange for about 10 seconds.
Basestation firmware: 1.8.10.1_13433
Hardware: VMB4000r3
Problem Solved.
The cell phone tower across the street is so powerful that it is blocking the signal. I put the system in my car and powered the basestation from an inverter and the cameras synced immediately. Once I brought everything back home the cameras worked fine.
Good idea. I tried again with all the bluetooth devices off (phone and computer). Same result.
There's no other bluetooth devices in the house that are on. I'm going to try another location to see if they has any better results.
I figured Netgear was looking for an excuse to blame someone else for why the cameras weren't pairing. They refused to even discuss any other ideas until I tried everything at another location first.
Problem Solved.
