Two accounts or two systems/locations on the same account
  • 1 Reply
  • 5493 Views
jsibbach240
 I have two houses one in Florida and one in Tennessee can I have two accounts or can I use the same app with two separate systems how do I go about doing that
Yes... there is NO limit to the number of bases ( nor locations ) on any service level... the limiting factor is the number of cameras on your service level.
So it can be run on one account.
To add a second base, just sign into the accout and click on the ADD A DEVICE ( main view page ) at bottom and add the extra base... then sync the cameras to it as normal.
You can do it away OR do it at you primary home ( I prefer this way as you can run, test etc ) and unplugged and move
If it is a remote location without access by friends, family, then you may want to add a UPS to the base/router/modem to eliminate some possible issues of power failure at times.
