Time between no motion and stop recording should be longer or configurable
5 seconds is way too short. Especially with how inconsistent the motion detection is. I think 10 to 15 seconds is more ideal.
The biggest problem with this product is it always stops recording prematurely, ie. when the subject is still in frame, just because they stopped moving for a few seconds. By the time it starts up again, there is a 10 second gap in the footage.
I've always found a "fixed" time worked better.... reset between files is aprox the same time
