The finger print login is missing
What happened to the finger print log in? I went in and changed profile but it still wants log in information typed in. What am I missing? The old app listed the e-mail and you just used finger print. Now you have to put it all in.
Yeah, I found that "feature" as well. The fingerprint options seems to work consistently, as long as you don't log out. I'm glad that it's working for you.
It worked so well and was very convenient to have the finger print login! I loved this function and hope the function will be activated again.
Same for me. Turning fingerprint sensor on in Profile and then logging in/out several times eventually resulted in it working.
same here
on iPhone 7 plus, The finger print login is missing after updating to the new arlo app
just an update
if you stay logged in the touch id starts working but when logged out the touch id is missing from the main login screen.
Hi Shayne
I'm running 12.4.1
Im having same problem, no fingerprint availability. Not on new app. Im running android os 9. Its a pain logging in both email and password every time for a quick check on cameras.
Try logging in and out about 10 times. I did this and the fingerprint option magically appeared.
updated to iOS 13.1 no chance
I am having the same issue. Fingerprint is working fine with the phone but not the new Arlo app. Verified it is turned on in settings. Android, version 2.9.2_25930. Release 9/23/19.
I think I’m going back to Arlo Legacy , it works there
Not shore what else to do
Updated to the last IOS verified Tuch if in settings but still not working
Could you please consider to leave us the Arlo Legacy app until this issue is resolved??
I just installed the legacy app and it works fine with IOS 13.1 Tuch I’d and averting else
Touch ID has been fine on Arlo Legacy app, but does not work in new app. Any suggestions? It is turned on in the app and on the iPad/iPhone, but does not sign in. Someone suggested leaving the app on permanently, but that totally defeats the purpose of Touch ID.
Thanks for that. Unfortunately I travel abroad using local sims, so I cannot use my US phone number for sms. There doesn’t seem to be a way to use email instead.
Samsung Galaxy A20 with Arlo Android app 2.9.2 - 26040
I have enabled Two-step Verification and Log In with Fingerprint.
I can log into the phone with fingerprint, but the Arlo app does nothing when pressing same finger to the sensor. Login via password works fine.
HI @rxn
Thank you for the link. Will contact Support asap
