Stored Videos Deleting
  • 1 Reply
  • 1755 Views
bullcat151
Hi,
  Is there a way to delete mutiple library videos at the same time? Having to click on one at a time is tedious.
Thanks,
            RJ
You don't say what device.... ??? TBMK all are on a per day basis ( only per day for select all )
On PC, hit SELECT and then all the video icons you want, then delete
ON Android if you hold on a vid icon it turns color ( in library ) and a grid box appears on top row... selsect mulitple then delete
Honestly tho, I don't recommend deleting any... Most use basic level (7 days) and they get auto deleted anyway
