Hi there
Since last arlo app update I can’t anymore find how to add a siren trigger when there is a detection. I tried with the mobile app and via web account. Same result.
I only find the button to set the siren on... but not a rule / trigger for a camera?
Does someone have a solution?
PS: I only have a smartphone / tablet on my possession.
Thank you
Thank you
kevinmartel,
When editing the rule, click "Add Device". This will allow you to trigger the siren when a camera detects motion.
kevinmartel,
Thanks James, it works.
Netgear, you should update your FAQ..
