Siren on Arlo Pro
The Arlo Pro also has a siren, I have 3 dogs will that set the siren off? Am I able to turn the siren off, if I wanted?
You can set the siren to ring any time motion is detected on any camera. The default is off.
If you dont want your dog to trigger the cameras then you would need to position the cameras in a such a way to prevent this.
See here
https://kb.arlo.com/1145364/How-do-I-turn-the-Arlo-Pro-base-station-siren-on-or-off
