Siren/Video
  • 5 Replies
  • 4372 Views
  • 6 In Conversation
Bigmrcia
Does the camera turn on everytime someone enters the room? Will it trigger the alarm siren in the system if the cameras are activiated? Do they work separately?
5 REPLIES 5
mbauer
You will need to setup modes and rules to tell the cameras when to record, how long, etc. "Modes and rules let you tell your Arlo system what to do in different situations. For example, you can set your Arlo system to record a 30-second video when the motion sensor is activated on a specific camera and alert you via email." In addition, the siren can be manually triggered via the Arlo app or by creating a rule to trigger it when motion or audio is detected. Please review the following guide that will assist with creating modes and rules. Let me know if you get stuck or have any other questions.
https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-modes-and-rules-and-how-does-Arlo-use-...
Yes if the camera is ARMED
Yes if set to go off, and yes you can turn it off if wanted and still have the camera function
rbiccw
Tested siren manually by clicking on "Turn on siren". Blew my ears out! Could not deactivate by clicking on "Turn off siren". What gives!
It has worked for me to be able to turn on and off.  App or browser?
rbiccw,
The siren can be disabled by physically pressing the button on the base station or pressing the "Turn Siren Off" button in the interface.
As mentioned above, what client were you using when you experienced this issue?
