Setup without ethernet access
  • 1 Reply
  • 9196 Views
cnaibryf
I do have WIFI signal but I do not have ethernet access.
Could I still use this system?
I believe that the cameras are ok ( WIFI ) but without the hut still can be connected?
Carlos
In order to use a wireless camera system without an Ethernet connection you'll need to use a WiFi extender with an Ethernet port. The extender will connect to your router and the base will use the extender's Ethernet port to get to the router and then to the Internet.
