Setup equipment
What ACTUAL equipment needed for complete setup.
4 camera system - arlo pro
Router ?
Modem ?
Home hotspot?
Router ?
Modem ?
Home hotspot?
You need a network already installed that also has an Ethernet port so the base can be plugged in. It depends on what you already have as to what you may need. The typical setup is a modem, router and Arlo system but others are using a hotspot with an Ethernet port or a hotspot with a WiFi extender that has an Ethernet port.
