Hello all!
I've had my Arlo Pro system (4 cameras) set up and going for about a year now. After some initial hiccups, all is well and I'm really happy with the system. So much so, that I recently bought another Arlo Pro system (3 cameras this time), to be able to have a closer base station to the rear of my property (splitting the 2 for front and rear coverage).
During initial setup, the second base station can not connect to the internet - the middle LED on the base station is amber. I've checked my router and I can see the base station has an IP address. I can ping it ok. All my devices in the house can connect to the internet ok. Even my original Arlo Pro base station has no issue (Can I rule out router misconfiguration?). I've factory resetted the base station about 5 times now trying to get it to work. I've restarted my router multiple times too.
In summary, my original Arlo Pro system has been going strong for about a year now, and continues to do so. My new base station cannot connect to the internet during initial setup, so I'm stuck at step one trying to add this base station to my network.
Anyone seen this before?
Thanks!
I know I could just connect the 3 new cameras to the original base station, but that will defeat the purpose of getting that extra base station - better wifi signals at the rear of the property.
Resolved...
Serice Outage started at approx noon on 11/24.
Tried several things from community forum (disconnected base, reset router / modem, played around with port 80, Reset Base)
Sent help email to Arlo (got a case number) - No help / response from Arlo.
Posted Question on this board.
Got response from several users - sharing the same issue - saying it was an outage from Arlo.
Disconnected the base for the day.... at about 8 pm - was not going to mess my day further....![]()
Had left the Arlo Base disconnected overnight.
Plugged it back this morning (7 EST).
Got the Green Internet Light on the Arlo Base!!! ![]()
Since I had factory reset the base (should not have done this!!!!) - had to go through the initial setup process all over again.
Synced all cameras again.....
Redo all my custom Modes that were created!!!!
Happy that the system is back up!
Unhappy that I jumped the gun on Factory Resetting the Base!!
Frustarated that Arlo would not post a general advisory about the outage on their website!!!
Even a generic message on the app that the server is down - please try later - would have told the users that the problem is not on the user end..... would have been nice!!!!
Have a good day all.............................................
Finally my internet LED went green but my camera LED is orange. Is this something I can fix or do I have to keep waiting on Arlo for them to fix this? I am so beyond frustrated right now. I expect them to do something to rectify this. Why did I drop $500 on something to have it only work for 12 hours? Ugh.
I still have the same issues. Of course it was after working on the system for hours and hours back and forth to the cold weather. The first issue started with black video and night and day settings then while working on it all the system went down but no word from Arlo so spent hours and hours up all night. Finally found this community posts and found out it was not me. Still no camera use but can view old library. web green light but cameras amber still. I am wih Spectrum and have no issues with them. Also wonder what else I need to do to feel protected again. Of course for new Arlo people this is not normal. Been with them couple years. First time this big issue.
It is now running as of 11/25/2017 this morning!
Attempt to resync your cameras... the led should go green.
( other non-connect issue appears to be server/far side related )
Arlo Base Station is up and running as of 11/25/2017.
Arlo is back up and running now. Hope yours is too.
Arlo is now running as of 11/25/2017. Hope yours is running!
Arlo Base station is running now as of 11/25/2017. Hope yours is back up too.
Same here. Internet LED is finally green. But it still shows that the base is offline. Tried to sync up the camera but camera is LED is orange.
Thank you! This worked
But Now cámaras cant sync!!!
Is this still part of the global problem?
Please your help and comments
What phone and OS ??
ps... the servers had issues yesterday and were down a bit
See Facebook:
https://m.facebook.com/story.php?story_fbid=1976975219181255&id=1540756022803179
and the Arlo forums.
Arlo Smart Home Security - NETGEAR Communities
Just another user
Wanted to share my experience...I also had reset and removed the hub. Needless to say I tried hitting the sync button on the camera and then running down the ladder and then hitting the sync button on the hub and it worked..Possibly because it had previously been sync'd?? I don't know but in the end I didn't have to take down each camera and hold it 1-3 away from the hub. Also it kept the name of the Camera etc as well.
Don't feel bad, we have these experience too. Once the internet is down we just have to leave the Arlo alone until it comes back up. Sometimes you will have to take the cameras down and redo it again to set it back if it doesn't respond. Have a blessing day!!!
JG
