Can I hook up a Seagate Backup Plus Hub 6 TB External HDD - STEL6000100 - USB 3.0 to my Aro Pro 6 Camera system? I am thinking of getting more cameras on my system and looks like I can get up to 10 cameras if I get the $150.00 a year subscription? I do not see the difference in getting two 2TB drives. Why not just get one large drive etc... Also is it better to get a solid state drive?
Thank you for all your help.
jared
Yes..As a PS to above, ONLY motion activated recording will go to the backup usb drive.
Based on a quick glance at the specs, it appears that the answer is yes. However (you just knew there had to be one, right?), you would need to connect the unit to the base instead of a computer. I don't think the front USB ports would work for Arlo although it could be an interesting test. More importantly, though, is the need for there to be a FAT32 partition which would mean you'd need to instantly repartition and format the drive to allow it to work. You'd generally be better off using a $15 thumb drive for Arlo and save this unit for your computer.
I would love a thumb drive but I do not think they make a 6TB one? That is not thousands of dollars. like the Kingston DataTraveler Ultimate GT 2 TB Flash Drive - USB 3.1. I figure the 6 TB drive will do a few months of recordings with 10 camera all recording 10 min clips etc... Not sure but its worth a try. Reason why I like the front is I am hopeing that I can plug a thumb drive into those and move stored pics to them etc... That of course is all dependant on the software from NetGear etc...
Thanks for the reply.
you can't access any of the videos from the backup drive directly any way ( without ejecting it and plugging into another device )
I use a 32GB stick run it for a month or two, pull it and copy all of , then put it back...takes a few mins
