Schedule mode - discrepancy between Arlo Android app and Arlo web portal
New Arlo Android app v 2.11.0_26065 has bug on Mode tab when running in Schedule mode.
The indicator for running in Schedule mode is missing - does display what mode is active, but appears as if mode has been manually set, and not set via your schedules. If you drill into Modes and tick Schedule and then tap Back, you WILL see the indicator. However, if you exit the mode tab, when you come back to Mode tab you will not see the indicator, and when you drill down into modes you will see your custom mode is ticked, and not Schedule mode.
Arlo web portal does not exhibit this behavior, however - on Mode tab in web portal, indicator that schedule is running is next to what mode is active, and when you exit the Mode tab and go back, it does show the indicator and does show that Schedule mode is running.
This is confusing - please fix.
I cleared the Android app cache and data, uninstalled the app, reinstalled the app and logged back in - no change.
This is a long-standing issue, at least with the Android app (no idea about iOS). DUe to this and other reasons, I tend to only use a browser for ANYTHING in the Mode tab. You can use a mobile browser if set to use the desktop version on the site.
