Rules - One trigger multiple device record problem
  • 1 Reply
  • 2812 Views
Delboyii
I set up a number of Rules within a special mode to do the following:-
IF Cam 1 motion THEN record Cam 1
IF Cam 1 motion THEN record Cam 2
But it only records one camera's output, is this supported or am I doing something fundamentally wrong?
No, that is supported and should work....
I always found setting cams to record same amount of time worked better but TMK shouldn't make a diff either.
Try and make another custom mode switching sense camera
