Reset/restart Arlo Pro camera remotely
I'm the future, do you believe you will have the capability to remotely restart/power cycle a particular camera? Of course, on vacation one camera went down. Bummer. It had a newly charged battery so I don't believe that to be the issue and worked perfectly when I left care. Sorta defeats the purpose of having the great camera and it not to work.
Base is up and other cameras ar up and functioning above my expectations!
I would love to see that, or something like that, as a feature in the future. Like a restart that does not require my being there to actually troubleshoot and/or fix it.
Appreciate it! Truly love the product. Just need to continue to grow tthe functionality with Arlo Pro product line.
Thanks, Sandy
Nice idea but I think the issue would be that if you cannot see the image etc. then there is no connection to the camer and as such the base would not be able to communicate to it to send a reset command. There may be a way around it of course.
If you are serious about your home or work security then look elsewhere! Get a ip Camera System with an NVR and some Blink XT cameras to cover the places you cannot run a cable to. You will NEVER regret moving away from Arlo!
