Record viewing advanced
  • 1 Reply
  • 1569 Views
Crab
Hello, everyone!
Recently the android app got some uppdates, some good some... Well must be used to.
The thing I would like to see some improvements is the Libary section, particulary when viewing a record, one may want to pause in some precise moment to see a face or licens plate number. After the update it is very hard to pause in a correct moment because you must tap once on the playback screen so that the pause button apears, then you must tap again to pause the video. It is allmost impossible to do that when zoomed in.
My suggestion is to put three buttons under the playback screen for "play/pause" and "next+previous frame"
Another small piece to add is that while in record viewing screen it is neat to have that sliding between recordings function, but because of that there is less place on screen to play the recording. The playback screen is so tiny now. Sure you can always go into full-screen view, but I liked it the way it was before update with the playback area from edge to edge of the screen. (and still have the slide to next record option)
Otherwise the android app looks and feels much fresher and more responsive I think. However looking forward to more advanced playback management options. Thanks!
pc2k17
Hero
Hero
Just rotating your phone sideways switches it to full screen, no need to tap. Much better than tapping the two arrows icon.
To get better control of the video, download the video to your computer and control, edit, etc with your favorite video player or editor.
