Since the Arlo app got updated, I am unable to figure out how to put the cameras in 24 hour armed when traveling. It is currently on a schedule. I used to be able to just put on armed and not worry about it. Any assistance would be appreciated.
My usual advice is to only schedule modes Arm Home and Standby, and reserve Arm Away for when you are actually away. (modifying both Arm Home and Standby as needed). Then set the enable lists for the schedule automations to "Arm Home, Standby".
Your other option is to put the system in Arm Away and manually disable the schedule automations when you leave.
Thank you very much!
