Not really sure what's going on just bought the system hooked everything up went well, except when I Livestream I can hear audio from the camera when I activate push to talk I lose audio from the camera I can press the microphone button and speak and it will transmit to the camera but no sound comes from the camera until I close the live feed and open it back up anyone run into this issue?
A new version of the iOS app that resolves this issue is now available. Please make sure you update to the latest version from the App Store. See here for details: Release Notes - iOS App 2.4.1 - 24th May 2017
Contact Netgear.... maybe they have an answer ; https://www.arlo.com/en-us/support/contact.aspx
Yes, it's a bug that started affecting iOS after the latest Arlo firmware IIRC. There are a few open threads about the issue. Hopefully Netgear can resolve the issue in a prompt manner.
Mrclay,
Camera position can be a factor in motion detection performance. It can sometimes take some trial and error to find optimal conditions for your Arlo system.
Take a look at the tips in this article to be sure your cameras are positioned for best performance: How do I optimize my Arlo Wire-Free camera’s motion detection performance?
If you're not willing to perform the suggestions, there's little we can do to help. These are motion detection cameras, not streaming ones so you MUST set the camera up properly so motion detection works as you need.
Motion detection of people is about 20 feet or so, if they're moving across the FOV, not directly at the camera. Positioning is key. Post a screenshot of the camera view for suggestions.
And we're talking the Arlo system here. The Q cameras, which are powered, do stream 24/7 but require the CVR option to access it. Recording is all done in the cloud with the exception of the Pro base and Q cameras which have USB or microSD card capability, respectively, for times when Internet access is down. If you want streaming cameras with local recording you need to look elsewhere. The configuration of how Arlo works is well-defined and available for research before buying.
United States contact information:
(408)-638-3750
Hi,
I cant get my camera to work properly.
2 way function that is, (using iphone) im taping the microphone its turning purple and i can talk,
but then i cant here anything from the other side.
So the sound from the camera disappears as soon as i start talking from the phone.
On the other hand if i dont start talking i can hear things from the camera, but not communicate, since
i press the microphone button the sound disappears from the camera and not coming back if im not restart the Arlo app.
Have updated the version etc.
Hope you have any suggestion on what to do!!
Best Regards!!
I have escalated this topic to engineering for review. I will provide an update when I have more information.
I had two lengthy support sessions with your techs about this issue, and they said they had no fix for it (this was last weekend). I was told they would call me back when they knew something. Today I get an email from Netgear saying my support ticket will be closed if I don't respond! I have nothing to say! The ball is in your court!
Hello,
I downloaded the new update, and it does seem to have fixed the bug, thank you! Cautiously optimistic... Really looking forward to using this feature!
