Hemicon wrote:
Jguerdat, what Android OS are you using? I'm using 7.0 and I don't see where I can clear the cache.
Android 7. Use the phone settings, go to Apps, select Arlo, Storage, Clear Cache (clear data basically resets the app as if you just installed while clearing the cache doesn't remove all settings).
read section on audio testing;
https://community.netgear.com/t5/Arlo-Pro/PRO-Camera-on-regular-Arlo-Base/m-p/1158554
As to audio low on an Android... yes.
But the audio is loud enough from other devices tested... So it appears it may not be the cameras but more the device used.
Some phones use sound cancelation and I believe this may be part of the problem
As to fixing it... try and turn off above if you have it OR try Speaker phone and see if the audio is louder
What device and OS on the phone...
Also , put in a trouble ticket to Support... if they don't know about it, it will never be fixed
As a PS, go to the app in device settings and try clearing cache...if that doesn't work , Id remove the app and reinstall to cover bases
Clear trhe cache on the device? I see no such option anywhere in the IOS app.
It would be in the phone settings under apps. I don't have iOS so can't give you exact steps. Android uses phone settings, apps, Arlo, clear cache.
My app works great! As for holding their position, I can't speak for the mounts as I used something different.
Hemicon wrote:
Robert what mounts are you using?
I am using these mounts that I purchased from Amazon. They work really good so far.
https://www.amazon.com/gp/product/B001D49TU4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Yes, not on IOS...
On IOS, delete the app and reinstall
On Android, go to settings, apps( installed), pick Arlo and on same page there is a clear cache near page bottom
On PC - depends on browser
This would make sure its a good install on the APPS, just in case ( you prob be asked to do it anyway if a trouble ticket was put in )
As to mounts, the problem is only with the magnetic ball mounts.
Second issue I kind of sort of figured out was that my wife also has an Android phone running 6.0.1 (Marshmallow) and her mic feature works like it should. When she speaks, the speaker is much louder than when I use my phone. That could mean one of two things, the mic on my phone is bad or the software isn't optimized for 7.0 (Nougat). I've had people on occasion tell me that they can barely hear me when I'm in a very quiet area like a car or office so I'm gonna see if changing my phone would resolve anything.
We are aware of an issue with audio on the Arlo Pro and are currently working hard toward implementing a fix as soon as possible. I will keep you updated with any new information I receive on this topic.
Thanks James. Same issue with LG G Flex 2
Just installed the cams and everything works great with one exception: the mic. You press to talk and the screen drops frames/slows to a crawl; mic works sporadically. Has there been a firmware update that fixes the mic problems yet?
Same performance on iPhone 6s+ and iPad mini.
MikeRiley,
This topic has been escalated and engineering is currently Investigating this issue. I will provide an update as soon as I have more information.
