Push notifications randmonly working deley
push notfication doest work instandly, it work randmoly it take 3 to 4 minute to work, there a serious bug on push notfication on arlo Netger push notfication on there server.
5 REPLIES 5
pcuser12345,
What device (iOS, Android) are you using that is experiencing this issue?
iOS notification take longer 3 to 4 minuets some time it doesn’t wotk it should get instant notification after triggering camera it used to work before not its broken
pcuser12345,
I'm not seeing widespread reports of this or able to reproduce delayed notifications. If you're still experiencing this, I encourage you to contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I think there is a bigger problem but most haven't noticed. I am getting some recordings hours later and even the next day. I also use IOS.
Push notifications doesn’t work well after camera trigger notification take 3 minute & late notification check the it should be instantly notification while camera triggered
