  • 1 Reply
  • 1888 Views
dbrowers
Since app update on 6/25 push notifications--tone and email--have stopped (they worked previously). I have tried all of the following:
log off and login, reboot phone, reset hub, deleted and then reloaded app, double checked all settings and push notifications...all to no avail.
I see on the message boards that this has occurred with previous updates. None of the solutions posted there have worked.  Arlo do you have a solution?
JessicaP
Hi dbrowers,
Are you still have this issue? What phone device and OS system are you using?
Also, try testing by using the default "Armed" mode if you're not using that mode.
