Problems since installing Eero
I have had my Arlo Pro since last December (worked fine). However, I recently installed Eero to improve my wifi throughout the house and now my base will connect to the internet but my computer and/or app will not find the base. Any suggestions?
Are you trying to reinstall Arlo fresh? If not, it should make no difference since you're not directly connecting to the base/cameras bu to the servers. Are the base LEDs all green?
