Pro camera battery always shows full charge?
My Arlo pro camera battery icon displays full charge all the time, even after days on use. Would it be the battery or the camera? Help.
Reinserting the battery should clear up any weirdnesses. How did you charge the battery? If charging in the camera, the charge is actually 80% of full capacity so leaving it plugged in won't cause problems (li-ion batteries last longest and have fewer problems when maintaining the charge between 40-80%). If using the external charger, the battery is charged to a real 100% capacity so it takes a while for the camera to display less than 100%.
