Pro 2 was working while plugged in, now won't
Hi all!
So, I have an Arlo Pro 2 camera that I decided to have continuously plugged in a little over a year ago. Everything was fine, no issues, but about a month ago it said that it had a low battery. I unplugged it at the outlet and plugged back in, and it showed that the battery was starting to build up.
Well, this past week the camera died, even though it was plugged in. Apparently unplugging it in doesn't work. Any ideas?
Thanks!
I'd start by charging the battery with a different charger that supplies both 5v and 9v outputs. If it won't charge, try swapping batteries to determine if it's a battery or camera issue.
