Has anyone experienced pixelating video in the first 2-3 seconds of the recorded video. It happens every time for me. It has great reception full Wifi bars... and does not happen with my original Arlo camera.. just with the new Pro.
Thanks, Manofice, for the link to the other thread, but my issue of the camera sensing motion and turning on every 2-3 minutes doesn't happen at night. It only happens during the day. Interestingly, what I think I'm finding (again today) is that whenever I open one of these videos, there is sound at the beginning of the video that sounds like wind hitting a microphone. I'm wondering if that wind/sound is turning on the motion detector (and, no, I don't have the camera set up to turn on video when it detects audio). I tried attaching an example video using the film strip/play icon above but it only asks me for a URL. I have the video saved in a file on my desktop and can upload from there but I don't have a website where I can post.
My router (R7800) provides great coverage throughout my home so I think a range extender might be over kill or just add more 2.4GHz interference.
The powerline adapter is what I'm leaning towards. Is anyone using this method currently with the Arlo base station? Any issues? I can make a new thread of this is derailing the topic.
Mykalika: I would start a new topic. But i'll chime in that I use a netgear extender as a WIRED access point and it works great. My house has wired ethernet throughout though, which it sounds like yours isn't.
mykalikai: I watched your video's, and I went back and just watch a bunch more of mine today and they are near perfect. I would definetly try and see if you can move your base a little closer to see if it helps. I'm very satisified with the firmware update as it pertains to fixing the pixelation.
Mark H..
(1.090.0.1_11011)
Mark H..
Mark, can you post a video to show what you are seeing?
Ok, gang... There are only two ways to upload a video or image. The sun and mountains icon is only for images like jpegs or PNGs and doesn't allow me to upload video. When I choose the video icon (film strip with play button in center), it only allows me to link to a site on the web (and not upload from a folder on my desktop). I have a number of video mp4 clips that I'd like to upload but I can't figure out the way to do this given the limitations of the choices. If I'm totally misunderstanding the previous advice, please let me know how I can make that work.
i know basesation has 128 Mb Ram im not sure they buffer to the ram or strem directly upload video net
Pcuser12345, I know that, i've stated numerious times about netgear using AWS. But that outage required reboots to fix the issue, who knows if any of that fixed our issues. You stated your camera isn't on the new firmware and it's having little pixelation...so ...I don't know what helped alleviate the pixelation.
Here are the YouTube videos that show Arlo issues. I think that ARLO should have the ability to upload video directly rather than have to post to YouTube, but that's just my opinion.
I came home after waling the dogs and I walked all the way up the driveway to the front door and put a passcode in the door lock, opened the door and started to walk through before ARLO motion detection picked me up.
In this video, the UPS guy walked up the driveway and put a box down in front of my door and he was walking away before ARLO picked him up.
In this video, the UPS guy walking all the way up the driveway to the door and was walking back to his truck before ARLO picked him up.
I'm still getting a lot of false triggers from the camera above my garage. An example is below.
False motion tripped.
This is another example of a different UPS guy today where it picked him up at the door putting the packages down.
This is a good example of pixilation. Same UPS guy today, different camera/ different angle.
The frustration was too much for too long for me so yesterday I ordered a Nest Outdoor Cam. It arrived this morning so I spent about 30 mins installing it. It was easy and it worked flawlessly. 1080p video, 24/7 live stream video. I can set zones to get alerts and zones not to get alerts. I have playback, can save a video clip, and I'm not missing anything due to laggy motion detectors or intermitent WiFi connectivity issues. Since I've had it up, I feel confident that I'm not going to miss anything and the video is very clear. Night vision, audio, microphone, etc. Yes, there's a subscription: $100 for first camera and $50 for each additional camera per year. I don't know about you, but I spend $100/month on a cleaning service, $100/year on access to Photoshop, and $100/week on food. Spending $150-200 per YEAR is not much for the ability of this service to be able to differentiate between a person walking by and a leaf or a dog walking by. My ARLO would turn on the motion detection because of rain! Anyway, I'm done with ARLO - at least outside. I actually ordered a second Nest Outdoor Cam today and will install it in the back tomorrow. I'll likely still use some of the ARLO cameras inside since they work pretty good inside. I just needed a higher level of confidence with the outdoor cameras than I was getting with ARLO. Good luck to you all as you work through these issues!
I have the same issue with the Arlo Pro I just purchased. I replaced the old Arlo with this Pro version hoping for better videio quality. It's very disappointed that every video the Pro recorded are ghosting and pixelated. The Arlo Pro is mounted at the exact same location as the old Arlo. Netgear, please fix this.
