Has anyone experienced pixelating video in the first 2-3 seconds of the recorded video. It happens every time for me. It has great reception full Wifi bars... and does not happen with my original Arlo camera.. just with the new Pro.
Just checked a few videos from today and pixelation is pretty bad on them. I'm starting to go back to my original thought that it is a server/datacenter issue. It seemed that the pixelation got better after that AWS outage, and it just so happened we had a firmware update pushed around the same time.
https://arlo.netgear.com/hmsweb/users/library/share/link/30FAE44CBD0DDD05_201703
https://youtu.be/Eb10f64xHy0
Pixelated/distorted video is often caused by poor camera connection with the base station. This could be due to wireless interference or range. If you are still experiencing this issue after relocating the camera/eliminating nearby sources of WiFi interference as troubleshooting steps, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I wish that was true..my Arlo pro does the same thing when its right next to the base station...FYI-I had my original Arlo 1st Generation Camera in the same spot/location and it DID NOT HAVE THIS VIDEO PIXELATION/lag issue..WHAT IS GOING ON...I wanted to buy 2 more Pro cam's but will not BECAUSE OF THIS ISSUE..
Now that I know that there is a donate button I will be able to share 90% of my pixilated video's with Netgear and Arlo - have fun with that Arlo!
Looks like I just got some new Firmware!! I'll test and keep everyone posted -
Base: 1.8.9.0_11528
Cameras (H8) : 1.092.0.1_11504
If so I haven't received notification for them yet..sure hope these updates fix Video pixelation issue..
My Arlo pro cam H8 is now on:1.092.0.1_11504
But My base is only on: 1.8.8.0_11528
I'm guessing because my base is the 1st generation base station not an Arlo pro base station..would I be right?
Lets see how night video clips work ..
manofice -
So I was having trouble with the pixelated video.. So over the past couple days I downloaded a WiFi analyzer to see if I was getting 2.4 infertence.. I ended setting my router 2.4 to Auto instead of picking a set channel.. this and the combination of the new firmware I have not had any problems for the past 24 hours but time will tell..
Feel free to reach out to me if I can make any other suggestions
Not necessarily true if the interference is near your Pro camera. An easy test is to swap cameras temporarily. If it follows the camera, swap at the store or open a case with support.
Why don't you try switching camera positions between your Arlo HD and Arlo Pro cameras? Also just because the camera is closer does not mean that it will have less interference - I believe it matters what is in between the cameras and the base to cause this..
Exchanging for another Pro camera that is going to do the same thing is not a fix. If you read this thread others have already tried that.
