PRO VMC4030 camera quit working, amber light on base station
  • 1 Reply
  • 785 Views
Rdumperth
VMC4030 cameras seem fine, blue light indicates sync, base sync turns from blinking green to solid amber
Which base? Check your router to verify the base has an IP address. You can try rebooting your router and base, in that order, to see if that helps.
