HI ,
I see You have taken the outdoor power adpter of your sight and can't find it on Amazon as well, should I be worried about the 3 I already have installed? Will there be a alternate in the future?
Using power is far better than having to recharge batteries?
Please let me know what is up!
The issue is with possible water infiltration between the camera and the plug. If the camera is in a location where that's not possible (indoors, someplace protected outdoors), there's no issue. You just don't want the camera connection to get wet. If in a location where they may get wet, it's advisable to stop using the power supply.
