One of two cameras goes offline
  • 9 Replies
  • 4284 Views
  • 7 In Conversation
General_Zodd
Recently acquired a new 2 camera Arlo Pro kit.
One of the cameras works perfectly. The other
will not stay linked to the base station. It will go offline
within 5 minutes or less while right next to the base
unit. Moving it about 30 feet away, it will go offline
within a minute or two.
I consider myself an experienced user with tech
(ie. I went so far as to look up the FCC ID filing on
the camera to get information on it's power output
and modulation scheme). FYI, it's about 230 mW.
When I put the camera on my 2-3 Ghz Agilent
spectrum analyzer, I measure nowhere near the
certified power levels. Leading to me believe an
actual hardware problem exists with the unit. Now
granted, I don't have the proprietary software to
connect to the microUSB port and interrogate or
put the unit into some sort of diagnostic service
mode - but I can measure it's RF emissions.
Explaining this to the minimum wage droid on the
other end of the "support" line is pointless. They read
off a script. Go outside it, and you get nowhere.
Everything she described I've done (power off cam,
base, remove cam, resync, yadda, yadda, yadda)...
all been done. Same issue exists - camera drops the
link within 5 minutes... .experiments also attempted
in an sterile wi-fi environment (ie. no other wi fi
emitters , other than the access point).
The camera is defective !
Model VMC4030, H7, Firmware 1.090.0.0_9945
It was part of the 2 camera kit - camera 1 good,
camera 2 bad.
Any Arlo reps here want to contact me to arrange
a warranty replacement ??? If not, I will simply return
the entire kit for a refund - searching posts it seems
my camera is not the only one that was replaced under
warranty for the same issues.
9 REPLIES 9
Interesting ...  Question, did you compare the 'bad' camera signal strength with te 'good' one?  Wondering is the good one was on par with specs ?
As to the replacement, It would prob be quicker to file a trouble report thru Netgear Support than get assitantance thu the forum.
That way you'll get an answer and can decide which way to go.
Marquise23
I am extremely curious on what the good camera's power output is! I have the 4 Camera system that was working well until recently.
I have one camera's mic is not working and the other camera has just recently been going offline! Seems like everytime I mount it back outside, it goes offline.
I already contacted customer service support and it's already been almost 2 weeks, with no resolution.
General_Zodd
I wasn't aware of the process. Ok I just opened a trouble ticket, and we'll
see what kind of "customer service" is offered up. I specifically requested
a warranty replacement. Listening to someone read off a script reminds
me of this Dilbert comic strip. They probably have zero hands-on experience
troubleshooting systems, much less comprehend RF or board level faults.
http://www.jerseysmarts.com/2004/10/02/dilbert-tech-support/
To the other poster, I did not specifically measure power on the "good"
camera. My guess (as an engineer) is there is proprietary software that
enables certain test modes in the camera, and they can ramp power
up or down, inject a test pattern, measure bit-error-rate, etc. No doubt
via the microUSB port.
For those that are interested, here is a link to Arlo's FCC filing info on
the camera
https://fccid.io/PY316200349
It's anyone's guess what sort of 2.4 ghz SoC they're using in their
design. I could probably open up the camera and look at the chip to
find the datasheets. Unfortunately, that definitely voids the warranty.
Finding other users with the same issues, lends me to believe there might
have been a bad "run"/batch of cameras with a known defect/issue that
they are refusing to acknowledge.
I'm still within my return window, and we'll see what happens.
hokeysmoke
Virtuoso
Virtuoso
Having been a recent recipient of a defective camera (after purchasing 9 Arlo cameras that work fine), I recommend the "drop us a line" email trouble ticket approach.  It took one round trip of details to check off with the entry-level support that got them to escalate to level 2 where I was immediately given an RMA number for an exchange, all within 24 hours.
Marquise23
Wow! All wihin 24 hours? Not in my case, been almost 2 weeks for me and still no remedy OR RMA!
My 4 cam system was purchased in November 2016. Worked well until Mid-December. First a mic issue, now yesterday, an offline cam issue. I have to see if I can still return it to the store. I am extremely upset.
Rogerwilco357
I have a five camera setup and two of the he from getting constantly bug out and loose connection to the point that it's very inconvenient, resetting and checked my batteries up and down the ladders . Hope-they figure out if it's hardware or software glitch and since mine are over a year if I have any chance getting them fixed.
Rogerwilco357
How long has this been going on?  I've had no issues with any of my cameras like this.  In the future, be sure to open a case with support so there's tracking - too many folks wait too long and fight a problem that a simple replacement fixes.
Rogerwilco357,
What is the signal strength like for the 2 cameras having this issue? Poor signal strength could be causing the camera to struggle maintaining it's connection with the base.
