Hi,
I bought 4 pack Arlo Pro over the weekend. Initially synching was an issue.
I had to remove batteries multiple time to have them sync to the base.
Eventually I was able to sync 3 cameras. 4th one wont sync. Eventually 4 synced but then one other camera won't sync. In essence I can't sync more than 3 cameras at the same time.
Another issue is that my one camera go offline quite frequently. Will have to re sync again to bring it back online. I kept the camera with 5 ft of base station and it does not matter. It keeps going offline.
Problem1. Can't sync all 4 camera's at the same time.
Problem2. One camera goes offline frequently no matter how close it is to the base.
Hope to get help here quickly. I like the system and the capability and potential but don't want to end up returning it.
Thanks.
Ok... something isn't right so maybe better to restart.
Take all the cameras and open the battery doors, pull batteries
go into settings and use REMOVE DEVICE for each camera.
RESET the base by holding the reset for about 10 secs till the front leds flash...give it time to reboot fully
When power and internet leds are green, replace battery, close the battery doors of the cameras
One at a time, re-sync cameras by QUICKLY pushing the base sync button ( don't hold ) and then the camera sync button
wait a min between each camera.
Hopefuly all wil be well and all will sync as should.
If problem continues, esp #2 while close to base, contact Netgear support.
Hi,
I reset the base and resynced the camera as you suggested. All 4 camera's got synched for an hour. After that 1 camera went offline. This morning one other camera went offline as well.
For some reason, the same two camera's go offline even if they are not too far away. I have one in direct line sight as base and the other one 10 feet away.
Something wrong with the system (base, camera, batteries etc).
Thanks for you help though.
akashagrawal,
It could be other nearby wireless devices interfering with the connection between the base and the cameras. Consider relocating your base station away from any other devices that could potentially be causing WiFi interference.
