Number of chargers with Pro four pack?
  • 4 Replies
  • 5421 Views
Desmodog
I was about to order a four pack and then stopped because I want to hard wire 3 of the cameras and am guessing they only include one charger.
Can someone confirm?
If that's the case I guess I'll have to order four single Pros. Hmm.
saw this in amazon review re 4 cam kit;
 no, there is one cable and adapter set and one in the box to charge them
best buy;
What's Included
  • Arlo Pro Indoor/Outdoor HD Wire Free Security Camera (4-Pack)
  • Base station with built-in siren and power adapter
  • Camera power adapter
  • Camera power cable
  • Ethernet cable
  • Outdoor security mount with screw set
  • Quick start guide
  • Rechargeable battery pack (4 pcs)
  • Wall mount (4 pcs) with screw set (2 pcs)
  • Window decals (2 pcs)
Don't know.....
But you do know that the cameras without the battery pack will run on a regular 5v USB adapter @ 1.5a
( but will not charge as they need qualcom compatable dual voltage 5v and 9v to allow charging )
Desmodog
Yep.
But I will have two cameras without dedicated power and I'd like to just be able to swap them out when either of them starts to go low.
best buy;
What's Included
  • Ethernet cable
  • Quick start guide
Desmodog
Ah, thanks for that! Cheers.
