Not finding the option to engage auto-triggering of the siren if there is movement on schedule mode?
I'm not finding the option to engage auto-triggering of the Alarm / Siren on the units if there is movement or sound detected within Schedule Mode. I see where you can create a rule within Custom mode, but then there is no option to enter activation times within the Custom Mode...
Seems counterintuitive and something that should be an option? Why is there not a schedule within Custom Mode? Am I missing something?
My store was broken into yesterday, and I thought the siren would go off by default if there was the loud sound of glass breaking, but that didn't happen. Bummed out.
It's not in the schedule which simply automates switching between the various modes you've created. Edit a mode, edit the camera you want to trigger the siren from and use the Add Device selection to be able to select the siren and its settings. Be sure to save as you back out.
