Hi,
With a Google Pixel 3 / Android Pie, I don't see any setting to override the Do Not Disturb mode. Not possible at the system level, and not implemented in the custom settings of the Arlo app (Jan 7 release). Do I miss something?
Thanks,
Sylvain
Phone settings, Apps, Arlo, Notifications, Notifications (again), Advanced, Override Do Not Disturb. You can also set a custom tone there if you like.
Oh, I had missed the "Notification (again)" step (no visual indicator)! Thanks, I appreciate the quick answer!
