Hi, I don't see any saved recordings on cloud under library section of the app. I have 3 Arlo Pro cameras. I thought Arlo Pro cameras are eligible for 7-day free cloud recordings. Isn't that true?
Thanks ! Sorry for the confusion. I meant Arlo Pro. I have three Arlo pro cameras. Anyways, I just figured it out. I had to delete and re-install the app and reset my base station and it seemed to do the trick. I now see saved cloud clips 🙂
It is true for Pro and Pro 2 cameras. But not Pro 3 or Pro 4 - they need a subscription for cloud recording.
