I would like to know how to keep the cameras in Armed Away mode so they stay on all day when traveling. It was so much easier in the old app.
Basically the trick is to only schedule mode switches between Arm Home and Standby (modifying the rules in both of those as needed).
Then the system will remain in Arm Away mode until you manually change it (or return home if you use geofencing).
