Hi
When power up the base station for the first time, the Ethernet port seems dead. The router/switch shows that cable is connected, but no light in the Arlo Internet LED. I Have tried different cables and verified switch/router with a PC with wired net.
Performed a reset of the base, no difference. Power LED goes to green after booting, camera LED to yellow.
No light in the internet LED (exept for Orange ->green during reset.)
Thanks in advance.
Problem solved.
To fast yesterday..
I have a Zykel P2812 combined TV/breadband/wireless router/switch.
Only one port can be used for internet, the remaining 3 are for television only, and gives no IP adress to the Arlo.
Using the one port reserved for PC/switch solved the issue.
Howewer, the «Arlo pro guick start guide», page 15 - Base Station LED Guide-, states « off, the base station is not connected to your router». True, but is had a physical connection, but the router is not giving it an IP adress.
Problem solved.
To fast yesterday..
