  • 5 Replies
  • 218293 Views
InsaneDiego
The new app is listed in the Play Store as incompatible with my Chromebook. The Chromebook is running the latest v77 of Chrome and it's only a year old. I see that one other user had the same experience but no answer. The legacy app worked fine. Is this a setting on your end that you can fix in the Store or ??
5 REPLIES 5
You should be able to use the web browser interface (https://my.arlo.com)
Let us know if that works.
InsaneDiego
Yes, that's the workaround that I put in place but the app still should work. Instead of 1 interface, my wife now has to learn two interfaces. If it never worked on that "computer" then I'd say ok, that's the way it works. Since it's worked for 2 years until this latest update, I don't understand why it should be incompatible.
FWIW, I agree that the app should work.  Though it's good that you have the workaround.
ShayneS
Hi @InsaneDiego
Have you tried contacting customer support & getting a case op regarding this issue?
I have attached the link here for you: Customer Support
InsaneDiego
I have not tried support yet. I came out here first. Thanks for the link. I'll give them a tap.
