I can’t get the app to sync with base station- can’t even find the model number listed so I can choose it in the app?
You don't select the model, you just select the base station section and follow the steps.
It still cannot find my base station
Un pwer the base, plug in the etherent first , then power base up...see if that helps
And tell us what the LEDs on the base are showing.
