Netgear Arlo Camera has pink image. How can I fix. S/N 48D4687AA0614 (Outdoor indoor camera wirless)
  • 1 Reply
  • 3469 Views
SCML
My Netgear Arlo camera has a pink image. Was fine for first hour then 1 has gone pink. How can I fix this?
henryfrombg
Hi - just discovered the same problem with one of my cameras. Read posts here which said contact Arlo/Netgear support. They're really prompt in replying and are going to send a replacement camera, then I send mine back. Hopeully this will work but a bit concerned as there seem to be a lot of these posts on the forum .... is there a fundamental problem?
